Comme je sais que tu lis l'anglais je ne vais pas traduire, mais voilà :
Hall sensors Only (EDIS, VAST, luminition, etc):
a) Link OPTOOUT to TSEL
b) Solder a wire between TACHSELECT and XG1
c) For 5V inputs fit a 470R resistor into the position of R12
For 12V inputs fit a 1K resistor into the position of R12
d) For 5V inputs solder a wire between the top hole of C30 and 5V on the proto area.
For 12V inputs, solder a wire between the top hole of C30 and s12c pad on the main board.
Adapte à ton cas
Adapte à ton cas
