  • Max Valeur Avance diagnostique XR25
 #5304  par raider
 02 mai 2016 10:50
Hello,
First of all congratulations for the excellent job done with adx definition files for converting the XR25 diagnostic to be used with TunerPro!
I would like to ask how can one alter the maximum value for ignition advance displayed at 'Dash' in TunerPro when using the 'Fichier de définition de trame diagnostique XR25 pour les calculateurs Fenix 3 de Renault Clio 16S catalysée' (XR25_Clio16S_cata_7852.adx).
The case is that I use it for my F3P 710 engine (ECU S101728102E / 7700861454) and the max displayed value is 45deg while the engine, according to my binary and XDF, can go up to 60deg. I use the XDF from E.M. for Siemens / Bendix Fenix 3A ECU Renault Clio 1.8 16S - Fenix3A - Version Soft 7494 (corrected for VDATE).
Of course I can upload any file needed to examine.
Merci beaucoup!
 #5317  par Manu
 04 mai 2016 08:23
Here a nex adx for you :
ADX avec valeur maxi avance à 60°
(51.9 Kio) Téléchargé 279 fois
